How to use the SQL tile
About the SQL tile
The SQL tile enables you to pull data from external SQL data sources into your dashboards and perspectives.
A typical example of an external database would be the System Center Service Manager database or another CMDB, but any data that is stored in any SQL database can be integrated.
By default, only Dashboard Server administrators can create and edit SQL queries in the SQL tile . To delegate permissions to other users see Signing and security for sensitive tiles.
How to configure an SQL tile
Since Dashboard Server version 5.4 you need an SQL provider to use the SQL tile. Your Data Warehouse is available as a provider by default but if you want to use any other connection you'll need to create a provider.
See How to add an SQL provider.
Add a new tile to a dashboard or perspective and choose the SQL tile.
Choose the visualization for your SQL tile:
Scalar
A single value such as a number of customers or incidents.
Example:
Grid
Line Graph
Shows data over time, in a graph with an x-axis (time) and a y-axis. You can show several objects, such as servers, in one graph.
Example:
Sparklines
Shows data over time (like line graphs), but each item gets its own graph instead of showing all lines in one graph.
Example:
Bar Graph
Visualizes both a number and the resulting bar width based on the number value.
Example:
Donut
Shows the results in a donut shape.
Example:
Status Icons
Shows the state of items as icons with different colors. You can display just the icons or together with a description. You can also use a background image and drag the icons into position on the image.
Example:
Status Blocks
Shows the state of items as blocks with different colors.
Example:
Connection:
Choose the SQL provider you want to use.
If you haven't updated to v5.4 yet, you need to enter a connection string.
For more information about adding SQL providers and entering connection strings see How to add an SQL provider.
Query:
To test the query you want to use, run your query in SQL Server Management Studio, so you can see any errors and amend as necessary. Make sure that the server and database you use in SQL Server Management Studio for this test corresponds with the connection string you used in the Connection panel.
After the test was successful, paste your query into the query string box.
Example: A query string to show the number of alerts
CopySELECT COUNT(*) from Alert.vAlert
How to use the page timeframe in your SQL query
You can use page timeframe variables in your SQL query if you want your query to consider the current page timeframe.
If you want to use page timeframe variables, you can copy them from the table below
When you use page timeframe variables, the dynamic page timeframe will be inserted as a
string
in your search query, script, field, or wherever you use the variable.timeframe.isoDuration
Use this format when you want to insert the page timeframe according to the ISO standard for time ranges (period of time).
Example: When them page timeframe is set to "last 12 hours" the string
PT12H
is inserted.timeframe.isoStart
Use this format to insert a "from" time when you want the starting point to be "now minus page timeframe". The page timeframe will be inserted as a starting time according to the ISO 8601 standard.
timeframe.isoEnd
Use this format to insert a "to" time when you need to specify the end time. The end time is always "now". The current time will be inserted according to the ISO 8601 standard.
timeframe.unixStart
Use this format to insert a "from" time when you want the starting point to be "now minus page timeframe". The page timeframe will be inserted as a starting time in milliseconds according to the UNIX standard.
timeframe.unixEnd
Use this format to insert a "to" time when you need to specify the end time. The end time is always "now". The current time will be inserted in milliseconds according to the Unix standard. Math.floor(timeframe.UnixStart / 1000)
Use this format when you want to use the
unixStart
time but need to convert it from milliseconds to seconds.Math.floor(timeframe.UnixEnd / 1000)
Use this format when you want to use the unixEnd
time but need to convert it from milliseconds to seconds.Fixed timeframe formats (without using the dynamic page timeframe)
Date.now() - 86400 * 1000 *14
This is a template format to express the fixed timeframe "14 days ago" (now minus 14 days in milliseconds). You can use this template to create your own fixed timeframe.
Date.now()
= the current date and time (now) in milliseconds86400
= 24 hours in seconds1000
= converts the seconds into milliseconds14
= 14 daysIf you want to use a fixed timeframe in seconds, you need to convert the Date.now() into seconds, for example "4 days ago in seconds":
(Date.now() /1000) - 86400 * 4
.new Date().toISOString()
A text based representation of "now". Use this format if you want to insert the date as a string in ISO 8601 format, rather than leaving it as a date object. How to use the scope in your SQL query (only on perspectives)
Note: Using the SCOM object only works on SQL tiles on perspectives, SQL tiles on dashboards can't use the SCOM object.
When you are using the SQL tile on a perspective, the query string field shows you a
mustache picker that you can use to insert dynamic properties into your search query. The available properties refer to the SCOM object ("context") that the perspective applies to.
Examples for dynamic properties of SCOM objects:
{{id}}
SCOM object ID {{displayName}}
Display name of the SCOM object {{properties.virtualMachineName}
Virtual Machine name of the server (class property) Every time you view the perspective for a particular object, Dashboard Server will automatically replace the dynamic properties and the SQL query will be executed with the actual values that apply to the object being viewed.
Example:
Your viewing the perspective for the objectLocal Server
, which has the DNS namemyserver.domain.local
.Query with dynamic property:
CopySELECT * FROM owner WHERE server_name = {{properties.dnsName}}
Resolved query when viewing the perspective for the object
Local Server
:CopySELECT * FROM owner WHERE server_name = 'myserver.domain.local'
Notes for using dynamic properties
Dynamic properties can only be used for values in your SQL query - you can't use them to dynamically generate sub-clauses or other non-values.
Don't use quotes in or around the mustache syntax when referring to string values. For example,
becomesserver_name = {{properties.dnsName}}
in mustache syntax.Mustaches used in SQL queries cannot contain any JavaScript (for example, string manipulation functions like
.replace()
)Mustaches may be used inside T-SQL expressions, for example:
SELECT COUNT(*) FROM ManagedEntity WHERE [Name] LIKE '%' + {{name}} + '%';
Query requirements for Scalars
Your query must return a single figure.
Query requirements and tips for Grids
There are no special requirements for grid queries, since an SQL query will always return a grid.
Tip: How to convert a Unix timestamp column into a more readable format with your query
You need to insert
CONVERT
into your SQL query string.For example, if your query string is
SELECT TOP 10 * from Alert.vAlert
anddwLastModifiedDateTime
is the name of the column you want to convert, your conversion would look like this:CopySELECT TOP 10 CONVERT(varchar(64), dwLastModifiedDateTime, 21) AS dwLastModifiedDateTime from Alert.vAlert
You can configure the date format by editing
21
, replacing it with a chosen format which can be found in the following article: MSDN: CAST and CONVERTQuery requirements for Status Icons or Blocks
The return data must include a
state
column which must contain the following values:healthy
,critical
, and/orwarning
(the values are not case-sensitive). Any other values will result in stateunknown
.The state values define the color of the status icons or blocks:
Healthy
green Warning
yellow Critical
red Unknown
gray My return data doesn't contain a state column
If your return data doesn't contain a state column, you can define a state column in your query. You need to define which data you want to be interpreted as
healthy
,critical
, and/orwarning
and useAS State
to put the results in a state column.Example:
CopySELECT Name, CASE WHEN Duration < 500 THEN 'Healthy' ELSE 'Critical' END AS State
My return data contains a state column, but different values
If your return data contains a state column, but the values are not
healthy
,critical
, orwarning
, you need to map the values you want to use to the valueshealthy
,critical
, and/orwarning
.Example:
CopySELECT
Computer as Name,
Max(TimeGenerated) as max_TimeGenerated,
State as OriginalState,
CASE
WHEN State = 'up' THEN 'Healthy'
WHEN State = 'down' THEN 'Critical'
ELSE 'Warning'
END AS State
FROM
StateTable
GROUP BY
Computer,
StateQuery requirements and Column Overrides for Line Graphs and Sparklines
Your query must return as a minimum a DateTime field and a Numeric value field.
Column Overrides
Here you define how the returned data is displayed. Use the dropdowns to specify which data/column you want to use:
timestamp
Here you define the time series for the x-axis of the graph.
value
show all: If there are multiple values, you can display these by ticking this box. Each value will get its own series (a line in a line graph, a bar in a bar graph etc.).
grouping
Query requirements and Column Overrides for Bar Graphs and Donuts
Your query must return a numeric field for the value and a string for grouping.
Column Overrides
value
Only for Bar Graphs:
grouping
Note: If you connected to an Operations Manager database that is on the same server as the Data Warehouse and used the connection string
global:dw
, you need to put the following in front of the query:USE <OperationsManagerDatabaseName>;
Tip: You may find some useful SCOM queries on Kevin Holman's blog page SCOM SQL queries.
Configure the settings for your visualization:
Settings for Scalars
Scalar
Color
Conditional formatting:
value
property and manipulate it with JavaScript String and Regex APIs. When you click on the mustache picker, you'll get some examples:Value is greater than something, less than something, etc.
For example:
{{value < 10}}
(The color you picked will be used if the value is less than 10)Value is present in the result
For example:
value.IndexOf('error') != -1
(The color you picked will be used if the string value "error" is present in the results)Value matches one of the regular expressions you defined
For example:
value.match(/healthy|good|up/)
(The color you picked will be used if the string values arehealthy
,good
, orup
Display:
, where123
.For scalars, you can only use the dynamic property
value
in dynamic links, which means the link changes when the value of the scalar changes. Since a scalar is just one item, it would also make sense to use a fixed link, for example the link to the website of which you are displaying the response time.For status icon or bars and the rows of a grid, you usually want to use a dynamic link since you get multiple items or rows that represent different things. You can use any of the dynamic properties the mustache picker offers you.
Examples for URLs with dynamic properties for popular APIs
Dynamic mustache properties and values you need to change according to your instance are highlighted in bold.
ServiceNow incidents:
PagerDuty incidents:
{{incident.html_url}}
Azure DevOps projects:
Azure DevOps builds:
Zendesk tickets:
Azure Application Insights
Settings for Grids
Grid columns
Grid options
Row link Allows you to turn the graph item(s) into links. You can either enter plain text to create a fixed link (URL always stays the same) or use dynamic properties to create a dynamic link.
, where123
value
Zendesk tickets:
Show column headers You can choose between showing or hiding the header for all columns.
Expand rows automatically Activate this checkbox if you want the row height to expand automatically based on the row content, for example if your grid uses increased text size, images, emojis etc.
Limit number of results displayed You can set a limit of the initial number of results displayed in the grid. If you have set a limit and there are more results to display, users will see a "show all" button below the grid.
Font size Use the slider to adjust the font size.
Resizing columns while in edit mode affects how the grid looks by default when users open the dashboard. Users can temporarily change the column sizes by dragging them, but those changes only last until they leave the page.Settings for Line Graphs
Data range
Display
Height:
Allows you to set the height of the tile with a slider.
Label
Show legend:
Label:
custom
Important note if you are using external API properties with hyphens for custom labels (Web API tile, Elasticsearch tile, Splunk tile)
Property names that contain hyphens (for example
properties.name-with-hyphens
) can't be processed due to a JavaScript limitation. If you want to use a property that contains a hyphen, you have two options:If you have access to the data source and can change the name of the property, change the name of the property to a name without hyphens.
Original property name:
New format:
Settings for Sparklines
Data Range
Label
custom
New format:
Settings for Bar Graphs
Data Range
Label
custom
New format:
Color
Settings for Donuts
Sort
Display
Size mode:
Display mode:
Color palette:
General 10 different colors without specific meaning Priorities 5 different colors representing 5 different priority states Health1 3 different colors representing 3 different health states
(red=unhealthy, green=healthy, gray=unknown)Health2 4 different colors representing 4 different health states
(red=critical, orange=unhealthy, green=healthy, gray=unknown)Pastel 10 different pastel colors without specific meaning Blue 4 different shades of blue from dark to light Orange 4 different shades of orange from dark to light Green 4 different shades of green from dark to light Pink 4 different shades of pink from dark to light Custom Here you can choose colors and map them to a value.
Click on Select color... to select a color and enter the name of the value that you want to display in that color. Make sure you spell the value's name correctly (case-sensitive), otherwise the color won't be assigned to it.
Note if your color mapping doesn't work (color stays gray)
If you entered the value's name correctly (case-sensitive) and your mapping still doesn't work, check if the mapping value contains leading or trailing spaces. Try to enter the value with and without those spaces. Alternatively, you can remove spaces from the mustache expression and enter the values without spaces.
Example:
Mustache expression with leading and trailing spaces in the values:
{{#if Status == "1" }} Healthy {{elseif Status == "2" }} Down {{elseif Status == "3" }} Warning {{/if}}
Mustache expression without spaces in the values:
{{#if Status == "1" }}Healthy{{elseif Status == "2" }}Down{{elseif Status == "3" }}Warning{{/if}}
Settings for Status Icons
Link options
item link:
, where123
value
Zendesk tickets:
Label
name Choose this option if you want to use the default label that has been created automatically.
New format:
Sublabel
New format:
none By default, no sublabels are shown. Sort
default By default, the sorting of objects depends on the data source. This can be alphabetical sorting or the order in which data comes back from an API request.
sort by
Sort by label or health state, ascending or descending
group by Group by label or health state, ascending or descending
Limit:
Allows you to define a maximum number of objects that will be shown. When 'group by' is used the limit applies to each group individually, for example to show 10 objects in each health state.
Icons
One long list Column list Icons only Settings for Status Blocks
Link options
item link:
, where123
value
Zendesk tickets:
Label
New format:
Sublabel
New format:
sort by
Limit:
Blocks
Click done to save the tile.
Walkthroughs
In this walkthrough, we will create a simple SQL Scalar tile to show the number of objects being monitored by SCOM:
- For this walkthrough we'll create a new dashboard. In Dashboard Server navigate to where you'd like the dashboard to be created. Hover over the + button and click dashboard.
- Give the dashboard a title, by replacing the text that says New Dashboard.
- A new tile has already been added to the dashboard. Edit the title by overwriting the placeholder value New tile with your own title.
- Set the connection string to
global:dw
In the query string box paste the following:
SELECT count(*) from ManagedEntity
- Click next and you should see a number appear showing the number of objects monitored.
- In the Scalar > unit box type
alerts
to complete this simple tile. - Click done.
Create a new SQL tile on a dashboard.
global:dw
CopySELECT alt.RaisedDateTime, alt.AlertName, alt.AlertDescription, alt.Severity, alt.Priority, alt.Category, vManagedEntity.DisplayName, vManagedEntity.Path
FROM Alert.vAlertResolutionState AS ars
INNERJOIN Alert.vAlertDetail AS adt ON ars.AlertGuid=adt.AlertGuid
INNERJOIN Alert.vAlert AS alt ON ars.AlertGuid=alt.AlertGuid
INNERJOIN vManagedEntity ON alt.ManagedEntityRowId=vManagedEntity.ManagedEntityRowId
WHERE alt.AlertName='Available Megabytes of Memory is too low'AND alt.RaisedDateTime >=DATEADD(day,-7, GETDATE()) ORDERBY RaisedDateTime descClick next and you should see a table of results.
In the grid columns section we are now going to rename a column header and improve its formatting. To rename a column click on the column title, in this case,
raisedDateTime
and overwrite this with your new column name, for exampleDate
.To format a column click on edit next to the column name, in this case for the Date column. For this column paste in
and click done. For more information see How to use the Grid Designer.Click done and then next.
You can use the grid optionsrow link option to add a hyperlink to each row.
Edit the URL below to insert your SquaredUp server name, or correct Dashboard Server URL, and then paste into the row link box.
http://SquaredUpServerName/SquaredUpv5/drilldown/scomobject?value=
Click on the mustache helper button
Click on displayName.
Click done.
Test that the row linking works.
To draw a line graph your query results must include a DateTime field AND a Numeric value field. This walkthrough uses a query to show the "Top 5 Servers with most Events" across all objects that are reporting events for 30 days.
Add a new tile to a dashboard, and then click on SQL.
Click on the SQL (Line Graph) button to create a SQL Line Graph tile.
global:dw
In the query string box paste the following query:
Copy-- Just in case we need a smaller sample size, create a variable for our StartDate
DECLARE @StartDate datetime
SET @StartDate = ISNULL(@StartDate, cast(cast(cast(DATEADD(DAY,-30,GetDate()) as int) as float) as datetime));
--Temp table to store our Top 5 Events
DECLARE @TopServers TABLE(
ComputerName nvarchar(255)
, LoggingComputerRowId int
, CountOfEvents int
--Find the servers that are collecting the most events
INSERT INTO @TopServers
SELECT TOP 5
elc.ComputerName as ComputerName
, e.LoggingComputerRowId as LogginComputerRowID
, Count(EventDisplayNumber) as CountOfEvents
FROM [Event].[vEvent] as e
INNER JOIN vEventLoggingComputer as elc ON e.LoggingComputerRowId = elc.EventLoggingComputerRowId
WHERE datetime >= @StartDate
GROUP BY elc.ComputerName, e.LoggingComputerRowId
ORDER BY CountOfEvents DESC
--Find our actual records
SELECT
ts.ComputerName
, CAST(CONVERT(VARCHAR(20), DateTime, 102) As DateTime) as DateTime
, Count(e.EventDisplayNumber) as value
FROM [Event].[vEvent] AS e
INNER JOIN @TopServers AS ts ON e.LoggingComputerRowId = ts.LoggingComputerRowId
WHERE DateTime >= @StartDate
GROUP BY ts.ComputerName, CAST(CONVERT(VARCHAR(20), DateTime, 102) As DateTime)You can of course use your own query, but the results must contain a DateTime field AND a Numeric value field, for a line graph to be drawn.
Click next and you should see a graph.
- Click done.
FAQs
Who can create and edit SQL queries?
How do I configure access to a database?
Access to the SCOM Data Warehouse
Access to the SCOM Data Warehouse is configured during the Dashboard Server setup process. If you are able to see graphs in Dashboard Server, SQL queries have access to the SCOM Data Warehouse (see How to check and reconfigure the Data Warehouse connection).
Access to other databases
To be able to query other databases, such as the Operations Manager database, the Dashboard Server application pool identity needs to be given the db_datareader role in SQL Server Management Studio for the database you wish to query. See How to configure access to a database for use with the SQL tile.
Can I use parameters to customize a SQL query?
You can use the following parameters in your SQL query:
On dashboards | Page timeframe parameters |
On perspectives | Page timeframe and scope parameters |
How can I get dates and times to show correctly in my Grid visualization?
If your grid columns show times in the Unix timestamp format (milliseconds), there are two ways for you to convert them into a readable date and time format:
convert the timestamp directly with your SQL query
use a custom template for your grid columns and insert the conversion there
Converting the timestamp with your SQL query
You need to insert CONVERT
For example, if your query string is SELECT TOP 10 * from Alert.vAlert
and dwLastModifiedDateTime
You can configure the date format by editing 21
Converting the timestamp with a custom template
You can use timeago
to convert Unix timestamps from milliseconds to show a readable date and time. You can either display an absolute time (for example, August 20th 2021) or a relative time (for example, 20 hours ago).
The parameters for the value you want to convert can either be true
or false
Show Absolute |
Show Time |
Without Suffix |
With Prefix |
Tip: The default setting for all parameters is false
. If you only want to change the first parameters, you can just use timeago(value, true, true)
and it will be interpreted as timeago(value, true, true, false, false)
Examples:
{{timeago(value)}}
To display the absolute time as the date without the time:
{{timeago(value, true)}}
To display the absolute time as the date with the time:
To display the time with the prefix "for" for relative time and "since" for absolute time (for example, "the status has been unhealthy for 10 hours")
Option A) Use the fourth parameter and set it to true
. This will insert the appropriate prefix for the absolute or relative time:
timeago(value, false, false, true, true)
Option B) You can leave out the fourth parameter that controls if the prefix "for" or "since" is inserted automatically. Since you left it out, it defaults to false, causing no prefix to be shown. Instead you insert the word "for" or "since" manually before the timeago function.
for timeago(value, false, false, true)
To convert a time value from seconds to milliseconds:
{{timeago(value*1000)}}
Example with a Pingdom property:
Troubleshooting
Webinars
The following webinars cover how to use the SQL tile to integrate with System Center Service Manager:
